4x4TruckinGirl
"Cowgirl"
It went from normal oil levels to 7.5 quarts low........ thats sort of a lot, It's got to be going somewhere.....
Okay, So heres another question, I just spoke with this guy with the turbo..... It is off of a 1994 powerstroke.... with a 1.1 inlet (does that make sense) Soooo, my question is, will this setup work on my truck????
Completely different animal.
won't even come close to bolting up to that thing without massive custom fabrication and then theres's other issues.
Try the simple checks FIRST. Before resorting to surgery or drastic parts purchases. Don't just throw parts at a problem, Diagnose the problem, then fix the problem. If you want to just throw parts at a problem without knowing what the problems is...well, than, I guess, you could apply for a job turning a wrench at the local dealership around here
First rule of mechanics is the same as one of the first laws of science, Occam's Razor, which basically states in a nutshell, the most simple solution is usually the correct one.
