Oil pressure issue
Johnm
89dualliehauler
Santa Rosa, CA
Hello again, I have been running the new 96 engine in my 89 and am a little concerned by the oil pressure gauge. It is running 2 notches above low. I wonder if the sending unit is different on the 96 engine than it was on the 89 engine.
Johnm
89dualliehauler
Santa Rosa, CA
Added note, i just installed a mech gauge at the oil filter housing and i am seeing 80 at idle and 90-95 at 2k rpm
i am guessing that i have a bad sender correct?
does it matter that i am taking a reading at the filter rather than the other side of the block where the sender is?
if the dodge gauges are anything like a ford's, they suck. if you're really worried on where the fitting is located, the "rule of thumb" is for every foot of distance from the oil pump, there is a 10psi drop in oil pressure.
Whit
lost in Why-homing
the OEM gauge/sender is junk..........I was gonna suggest tapping the finished (polished) side of the filter housing but thats exactly what you did
.....you have good oil pressure dude :thumbsup:
rebel_horseman
Rt. Wing Extremist
West Florida Republic
Yep the old school gauges are crapola. I was having issues as well and replaced the sender and now have somewhat better pressure. I wouldn't worry about it.
Johnm
89dualliehauler
Santa Rosa, CA
is filter housing an accurate place to read pressure?
if you have an issue down line from that you will see it in the gauge right?
Johnm
89dualliehauler
Santa Rosa, CA
This is the pressure it reads...
i think i am just going to look to all new gauges...
Johnm
89dualliehauler
Santa Rosa, CA
The New Gauge on the filter housing
Here is a pic of the gauge I added
