Have a strange thing that for some reason just happened.I changed oil in my truck and filled the pan with 10 qts. Rotilla oil and went the motor is not running the oil dip stick shows just a small part of tip with oil well below the full mark.Before changing the oil even when truck has set you could check the oil on dip stick and was always full.Does anyone have any clues as to what is going on?
