oil leak at turbo and pedistal new o -rings still leaks ????
7.3 powerstrok
u.s.a.north
truck is down 100 miles away ,replaced o rings ,removed the ebpv rod and pluged the hole ,also removed the exhaust plate and shaft everything back on let idle after a few minites oil stream leaking right down from under the turbo could something be cracked on the turbo ?
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
yes. remove the turbo and put about 40-50 psi of air to the oil inlet. last one i fought with ended up being a cracked cartridge on the turbo. this was on a 96 f350.
m2rtin
