Oil leak advice
jdphish
Mississippi
My 2002 powerstroke
7.3 has been sitting up for 7 months as I slowly rebuild the frontend. Today I noticed this oil leak I had never seen before. I am concerned becuase 1) it never had a leak before. 2) we had a hard freeze after I took
bad water pump off.
Looks like its coming from around the freeze plugs. Why?
Any ideas on cause or repair would be great. Thank you
Not sure what freeze plug you're talking about. Appears to be coming from higher up.
jdphish
Mississippi
79jasper, thanks. On the first pic there is a plug on front of block. It may not be called a freeze plug. With a square inset. On second pic is same type of plug. Oild could also be coming out from front engine "cover" that is directly behind the water pump. Not sure. I wonder if rainwater got in cooling Passages and froze would
Cause this?
jdphish
Mississippi
Another thought just occured to me. Could it be that the cold weather (low teens) shrunk the metal enough that a small amount of oil leaked? Any comments would be great. Thanks
Some reason my reply didn't go through.
Those are just port plugs. Could be oil behind them.
I doubt enough rain water would have gotten in there to allow it to freeze.
jdphish
Mississippi
79jasper, thank you. There is no oil on the ground. I think I may take my chances and button it up as is. And hope engine tps will expand things enough to stop any seep.
Too risky? Thoughts?
Honestly I would run it.
It "could" be the front cover.
But without a actual steady leak, it's hard to tell.
greenskeeper
PA
you call that a leak? Just drive it and it'll probably clear itself up.
My definition of a leak on any older engine is something that leaves a puddle to mark it's territory.
94f450sd
somewhere,ma
If I remember correctly there are a couple long bolts that go through the pump and cover,correct?(been a while since I tore one apart.)
You will seep a little oil out from behind the cover.the top of the cover houses a couple of oil ports.
I'd run it.thats not anything I'd be concerned with.
jdphish
Mississippi
94f450sd, you were correct. After I installed the new water pump the leak/seep stopped. I have not yet cranked the truck but should soon (within the week). Thank you
IDIBronco86
