Oil Filter help
fields_mj
Brazil, Indiana
I've been running the FleetGuard FS1281 fuel filter on my truck and I'm tired of having to deal with the piece that screws onto the bottom of the filter. I know that Fleetgaurd makes a filter that fits our trucks and has all of this built in, including the drain valve. Can anyone help me figure out what the correct part number is?
Thanks!
Mark
Rot Box
Northern Utah
Lewiston
I'd be interested in knowing the part number as well. The Baldwin BF1222-SP eliminates the bottom portion. Been using them for years they're very nice :sly
gandalf
Senior Member
CA &/or Maine
Try a WIX 33617. My notes mention this as a single piece fuel filter for my truck.
fields_mj
Brazil, Indiana
Thanks! I'm trying to find something that filterbarn.com has in stock. That donaldson number gives me some parts I can cross reference.
fields_mj
Brazil, Indiana
Looks like they have a Luber Finer LFF 1223 and a Baldwin BF 1223 in stock. Anyone ever use a luber finer? Also, if the filter has a sensor port, will it have to be plugged if I don't have a sensor?
sensor port comes plugged, napa number 3417
Rot Box
Northern Utah
Lewiston
The BF1222-SP has the threaded fitting/threaded port for the sensor. From what I can tell the BF1222 (without the SP on the end) still has the drain but does not come with a sensor port.
