Oil cooler is done with Pics & Video
dieselgiant
Dieselgiant
Atmore, AL, USA
Finally the oil cooler has been rebuilt and it needed it real bad.
Thems the gaskets you need.
You can see all the bolts to the rear header in this pic
And now they are lose. Socket sizes: Front header bolts are 9/16, rear header is 1/2. Jack the engine up and slip the cooler bundle out. If the engine is up high enough the cooler will come out with no problems except it will endlessly drip oil all over you until it is sitting on the ground and out of your hands.
I placed it in a vice and beat the headers off with a rubber mallet, and they did not want to come off.
Looks good
Ewww
The culprit, both big o-rings were very hard and brittle
This stuff worked out great. Still used the floor jack and something heavy technique to press it together, but it went really easy. The main problem is getting the big o-ring to slid in.
YAY
I was suprised by the lack of pics involving jacking up the engine. It seems straight forward, and it is, but pictures are worth a thousand words. Just be careful. The board cocked sideways the first time as the jack went up and the board slipped out. Use a Bottle jack if you have one. The your fingers under a 1000lbs of crushing force would not feel good.
Here is the video explanation http://www.youtube.com/watch?v=24E0Bc1ifgI
Rot Box
Northern Utah
Lewiston
Great writeup ;Sweet The more I see these the more I think I should probably rebuild mine soon--before its too late.
WilltheThrill
Arizona
my troubles.....
well I was going to add some alum welds and clean up but I found another on craigslist, so well see. also the fron head had been eaten away at round jacket.
hotrod316
rockaway nj
i did mine it came out with out jacking up the motor.
QUOTE=dieselgiant;623717]Finally the oil cooler has been rebuilt and it needed it real bad.
Looks good
Ewww
YAY
Here is the video explanation http://www.youtube.com/watch?v=24E0Bc1ifgI[/QUOTE]
WilltheThrill
Arizona
well my craigslist guy wants me to wait till the 17th for the 25 dollar oil cooler he has to sell, does anyone have both the front and back oil cooler heads that are in good shape for sale?
smvdiesel
Kendallville, IN
Can you tell me approximately how long this job takes? I'm a pretty good mechanic, but I've never done one of these before. I did the water pump tonight, and while the system is drained, I figure I should rebuild the cooler. I've been getting oil in the coolant ever since I bought it a couple of years ago. Parts are on order from Rock Auto.
Thanks,
smvdiesel
WilltheThrill
Arizona
Well so far I can only speak on pulling the oil cooler out and taking it apart. 20 min to "cleanly" get it out and 45 min cleaning and discovering how bad may corrosion is.
