93fordturbo
I wanted to change my oil pressure sensor and CDR valve. I have an 85 6.9 with a banks gated turbo on it. My oil pressure says below normal almost all the time, it does go to the "N" sometimes tho. It used to work or read in the normal a couple months ago. It also uses a bit of oil. Maybe a quart every fill up. (2 tanks). Was thinking my CDR could be using oil? The truck runs pretty good and doesn't blow much smoke. Doesn't leak either. I just wanted to know maybe a part number for oil sensor and CDR valve. Or if I can just go to parts store and tell them what I need. Also wanted to know location of each on motor please. Thanks in advance.
