PwrSmoke
After our conversation a couple of weeks ago, I finally got around to reconnecting my Racor bypass oil filtration system using the port Justin (cdx825) told me about at the rally. I removed the AC compressor a slid it out of the way. The plug came out easy. I installed the 90 degree JIC fitting for the return and connected the hose. Reinstalled the compressor. Reconnected the feed line intot eh oil gallery port near the oil filter, started the engine , checked for leaks and oil flow through the bypass filter. All A-OK. Shut engine off, checked oil and topped off. Took a nice little test drive and rechecked for leaks... A-OK again. Super easy! Thanks Justin for clueing me into an easy solution and thanks to the others for confirming these ports were designed for just this purpose. I snapped a pic with the crappy camera phone (pretty sad for a guy with a $2K camera outfit). To me taking pictures is like work, so I don't do it much outside of my work.
