http://cgi.ebay.com/ebaymotors/HX40...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
what about this kind of turbo?
i know its not gonna hit max boost and i wouldnt want it to haha but for 340 bucks you would have a serious turbo that will give you back as much boost as you want for as much fuel your putting to it.
I guarantee anyone, you casn get a junkyard turbo for under 100 dollars. I recommend rebuilding it but, if it has a tight shaft in it still then go ahead and run it as is.
you would, but, you just have to make sure you can get boost from it at an rpm you can hit. if it just starts hitting 5psi when you are at 2800rpm, thats no bueno.
ya but say you get a beefed up turbo like the one i posted or similar. crank the fuel up "bb" code injectors or moose misters if you can afford them. your going to have the max boost for your money id think
i looked at the ebay charger again. you are gonna need some heavy fuel or serious rpm to enjoy that puppy. its running a big AR and a 72 wheel. basically it will deliver a lot of boost, 40psi easily but, it needs a lot of exhaust to spin it.
what about those ebay turbos http://cgi.ebay.com/ebaymotors/GT30...298034513QQptZRaceQ5fCarQ5fParts#ht_500wt_749 that idea crosses my mind almost everyday but where to get a intake hat and exhaust manifold ive been wanting to stop by our ford dealer ship and see about getting these little things
o so i guess it wont work for an idi. what about like a factory 6.0 charger? and on another note did you add those "g" code injectors or where they already in there?
