OEM fuel sensors
jrisingmoon
Pensacola
does anyone know the electrical specs for the fuel sensors? I have an OEM sensor with an aftermarket gauge and need to know if the mix-and-match setup will give me false fuel level readings. I have the aftermarket gauge data somewhere for comparison.
jrisingmoon
Pensacola
The sensor that comes with the gauge says 240-30 ohms but I'm assuming that this will change when the sensor is cut to size. I have an OEM sensor lying around in storage. I'll do a few tests with it and see what I come up with. I may have to put a resistor on it...
Freight_Train
Traitor to the brotherhood
Gadsden,Al
Per the Autometer site
GM
Most 65-97 0 ohm empty 90 ohm full
most 65 and before 0 ohm empty 30 ohm full
Ford
Most 88 and earlier 73 ohm empty 8-12 ohm Full
Most 89 and later 16 ohm empty 158 ohm full
Cv axle
