Np 205 Married Transfer case
smitty429
Dayton, Wa
Does anyone know if the Np205 will mount up to a 1985 T18 tranny I know it did to the earlier versions. I cant keep a BW 1345 in my 1985 f250 w/6.9
if it is a ford transfer case, the mount ring is a bolt in. the input shaft will need to be checked on the spline count though.
junk
Paullina, IA
I've got a np205 hanging on the back of my t-19. It bolted right on. I did have to notch part of the mounting ring to give room for the shift rail to move. So I'm guessing it will work. You will probably end up reworking your drive shafts as the NP205 is shorter than the BW cases if I remember right.
MadScientist
