Not starting
jose.castillo.921025
Abilene, Texas
So I put a new starter in my truck. I tried to turn it on but only got like 4 cranks before the batteries died. I replaced the bad one had the other one charge and it started. It ran fine the rest of the day. I tried to start it this morning and it just turns over. I know its getting diesel. I get a white cloud of exhaust when its turning over.
1986 F350
crew cab
6.9 IDI
C6 transmission
Clb
Another old truck
nannyfornia
First guess both batt's were bad, slow crankover will not fire these engines!
Waystro
No Class
South Texas
Both battery's start the truck go get another new battery
I would Also check your GlowPlugs they could be burnt out replace with Motorcraft Berus or I've had Goodluck with DieselRX Plugs get a test light and check all your connections ie GlowPlug controller-harness etc.
White smoke out the tail pipe during cold cranking tells us the glow plugs are not working. So find out why they stopped working. Could be a burned out connection in the engine main wire harness or failed plugs but your plugs are not working.
Clb
Another old truck
nannyfornia
Its in the stickies.
Or tech section.
Alleycat
