I had a fisher 7.5 ft on my 87 250 super cab since it was new. Yes fisher said no to putting it on a diesel 250 and it was because of the weight. I had the hd 4600lb dana 50 ifs front axle. I put an extra leaf in the front springs, now you may be able to get air lifts for them, that was not an option then. I had no problems with it. I sold it to a local guy with 300,000 miles on it and I still see it on the road. Back then Fishers were much heavier than the the other brands so the others had no problems putting their plows on a 250 diesel. I scaled it and it was like 4000 ibs on the front axle without plow, so it was barley over the limit with plow on. You will be fine, but you will need to add spring.
I also had a 1995 f-350 4x4 dana 60 powerstroke with a vulcan 880 10 ft wrecker body on it. It had a minute mount 8 ft fisher on it. It scaled at over 11,000 empty without plow. I did not have to add spring to the 350. Cant remember axle rating.
If it is the original minute mount or the one that the head gear/lights stay on the truck with the plow removed and it came off a diesel your golden, if it came off a gasser the mount won't fit around the radiator support. I don't know about the newer mounts. Is it an electric hydraulic pump or belt drive pump?
