Noise Level
DieselChemist
Raleigh
I have heard that these 12v engines are quite noisy. How much louder are they than a 6.9 IH?
Thanks
Bill
holtzer1
missouri
they are noisy yes, embrace it, its what a diesels all about. it gets better when you can tell the difference between a 12v, 24v, common rail ctd, powerstroke and d-max just by hearing one idle.
bentwings
minn
You should hear my 24 valve with a straight pipe behind my appartment when it's -10 outside.:thumbsup:
Even the garbage guy waves at me haha ;Sweet
argve
Resident Fruitcake
Gwynneville, Indiana
It's louder that's for sure but surprisingly it's not any louder inside the cab - this is because Dodge actually used sound deadening materials throughout the cab to help isolate the rattle. When you pull up to a drive thru or the like you will have to shut off the truck to order when in a 12v I have read in mags that the Common Rail Cummins you don't have to shut the truck off because it's quiet enough but a 12v - oh baby they are the ones with the loudest rattle.
geonc
SPIDER BAIT
NECKVILLE North Carolina
Thinking of jumping ship Will :angel: LOL
I got news for ya....the '99 24 valve I was driving when my PSD was down made MORE noise at idle than the PSD LOL
Not to mention the 24V had full stock exh and mine is as empty as my wallet:D
You can say you have truly become one when you can tell them apart under full load:hail ;Sweet ;p :D
DieselChemist
Raleigh
Not jumping ship just a redirection. I plan on keeping the ford but it is not a crewcab and in about 5 years I will definately need a crewcab. So I was thinking about getting a 96 or 97 F350 crew cab and putting a cummins in it. Doing this all while I am still driving the 6.9 so I can do it right. Heck, a newer 6.0 trucks are going for 20-25k with 150-200k miles on them. I thought getting a blown F350 and putting cummins in it would be cheaper than buying one with over 100,000 miles on it and having the benefit of a brand new engine. Judy already complains about the noise from the 6.9 so I was thinking the cummins was going to be too loud for her. Am I going the wrong direction with this or does it seem logical
Geo did you get my last pm, that's the problem of having a friend for a moderator, I can't get away with impure thoughts
bentwings
minn
:D If you think a 24 valve is a bit noisy then go with the common rail. they actually are pretty quiet. You can also put sound deadning inthe cab.....maybe have your cake too :D
DieselChemist
Raleigh
I'm reluctant because of all the electronics. I like the idea of putting sound deadner in the engine bay. how much will this reduce the noise
argve
Resident Fruitcake
I don't know how much sound deadening the OBS Fords have but adding some will only help even if it already has some from the factory. Only problem with the aftermarket sound deadening material is you have to pull everything out of the cab (seats, carpet etc). Then I believe the 12v would be quite enough. Now outside the cab it's a loud thing but roll up the winders and it's a totally different story.
gumper
Mine isn't very loud. Run good synthetic oil, it actually made mine quieter. As long as you have a muffler and a silencer ring it's good. My gas motor truck is louder.
Rocket04
NM
I read from another site that adding a quart of 2-stroke oil in the fuel quiets the diesel a bit.
MadScientist
Staff online
