Noise in front end
chevy6.5
West Creek, NJ 08092
I have a 95 2500 with 281000 miles, and there is a woomph noise in the front end on the passenger side, it gets loader as you go faster. I changed the tire and checked the axles to make sure nothing was broke. I also checked the rotor/caliper while the tire was off with everything looking good. Im running out of ideas. Has anyone encountered this on there truck?
onetonride
onetonride
Albany Oregon
i have the same problem on my ford...only it is on the driver side!!!! im just as lost as you.... good luck!! :dunno
nitrohogg
nitro ******
outside chicago
ahhh yes...it's a square tire or a wheel bearing!! run yer hand over the surface of the tire, if it's lumpy try rotating them, if not 9 times outta 10 its a wheel bearing.
JU57US
