No power
Tim lindell
Texas
Also the throttle response is insanely better and it will now black smoke occasionally. Once i get these first problems corrected i intend to tackle the other issues and eventually start upgrading. Not fully able to test at highway speeds yet due to desperate need for front tires ( death wobble)
Thewespaul
Bulverde, Texas
Mr gasket 105p. If you search around on eBay you can pick them up for less than $100
Joseph Davis
Lompoc, CA
What I did, replace with cater diesel fuel pump 110 GPH 8 to 16 psi, added fuel pressure regulator set at 5 psi, and installed five wire relay with a glass Diesel filter before pump, so I could see what was happening with fuel before pump. Works Great. The total cost was around $130 but well worth it. You will have to adjust your fuel pressure regulator so it does not blow to much black smoke. But a good Mechanical pump $45 no adjustment needed? Good Luck
