>>> NIPPON DENSO INJECTOR PUMP <<<
MIDNIGHT RIDER
I have searched and searched to no avail; I need descriptive information, such as a service-manual, for a 2-cylinder ND injector-pump.
This pump is on a 1972 2-cylinder Mitsubishi R2500 tractor.(Vietnamese issue)
On the tag it reads :
NIPPON DENSO
ND-PE52A608320RND294 (I believe that "5" might actually be an "S" ; I'll check it out closer with my better spectacles)
90000-294-2
5GO238
34161-50190
I can't decipher the Japanese writing that identifies each of these lines of numbers.
This pump is 2-cylinder, of course.
It is rather large, being almost as large as the engine block itself.
There is an integral, removable, diaphragm lift-pump on the lower-left of the pump housing.
There is a tiny dip-stick and oil-filler/breather on the rear portion.
The injector-lines are straight up on top.
Rear of and slightly to the left of the second injector-line is a pencil-sized "cap" that, when pulled up and out of it's sleeve, is attached to an inch-long brass rod that has an O-ring/groove about midway of it's length, such that it is a snug friction-fit. (I have no idea as to it's purpose.)
Any information would be appreciated.
gandalf
Senior Member
CA &/or Maine
This isn't the one you want, but looks moderately close, other than the fact that it's for a 4 cylinder engine. If nothing else it may point you in the right direction.
MIDNIGHT RIDER
I don't see anything. ????
Seller is located in Te Awamutu, Waikato
Where in the world would that place be? Hawiian Islands?
Found it. Te Awamutu
Te Awamutu is a town in the Waikato in the North Island of New Zealand. It is the council seat of the Waipa District and serves as a service town for the farming ...
gandalf
Senior Member
CA &/or Maine
Do you mean you didn't know that, Bill?;p
MIDNIGHT RIDER
Although it is hard to compare sizes from a picture, I believe my 2-cylinder pump is every bit as big as that 4-cylinder.
Other that the injector-lines poking straight up, there are few similarities.
Where that pump has the inlet and whatever that other business is, mine has a pump-mounted diaphragm lift-pump.
One thing I must say for ND pumps, they must be tough; the one I have has suffered years of hard use and complete neglect and is still up and running.
I would just like to know what all the little extras are for and better understand it.
Every time I look it over, I find something else I did not know it had. :)
radeon1314
