I came over from the old 6.9 side of things. I just picked up a 97 powerstroke crew cab manual 4x4 for a decent price since it needs quite a bit of work. I'm going to need some advice because my knowledge is limited on what's common etc.
First, brakes suck.
Like, will barely completely stop you. Fluid is topped off, no grinding screeching or anything like that. They work pretty decent if you're up to speed and slowing down for a pot hole, but other than that, you can barely come to a complete stop. ABS and BRAKE light are on. Thoughts?
Next. Clutch pedal doesn't work.
In terms of "doesn't work" i mean it doesn't do anything to the clutch itself. It has about as much pressure to the pedal as a disconnected ebrake pedal, though it does return to the top when released. I replaced the slave cylinder with high hopes, but no change.
First, brakes suck.
