New injectors and injector lines?
jrollf
Houston, TX
I believe the 6.9 #1 injector line is the same total length as the 7.3L line plus the adapter, so no change in timing.
I ran a 6.9 #1 line on my 93 for several years after I had the original crack on a road trip, I eventually found the "correct" line and reinstalled the adapter on my truck.
Brian VT
Maine, USA
So there's nowhere to buy decent new injector lines?
I replaced the pump and injectors and now I'd like to replace the lines.
I don't know, but I've got multiple used sets just in case...... and several IPs, and a couple motors...... and trucks. When you deal with old stuff that they don't make any more it's good to have not a couple but a few.
Brian VT
Maine, USA
New pump and injectors.
I have a leak at one of the lines coming out of the pump.
It's one of the low ones that can't be reached without a $160 socket.
I figure if I've gotta disconnect all those lines again then I might as well get new lines also since I'm in this deep with my $$$.
Any good sources for new lines? Are the ones linked here really worse than 33 year old ones?
Brian VT
Maine, USA
Was hoping to get a supplier recommendation like we have here for injectors and pumps (which I bought those from).
I don't think that there are any special suppliers of injector lines like pumps and injectors.
