Well got it pretty close now just need to add fluids, put the radiator in, get the down pipe snaked in with the pyro sensor on and hook up the gauges then itll be ready to start. Figured out my wiring for it just used the same setup that the 6.9 had on it just cut the glow plug ends off the 7.3 harness and soldered em in after I taught myself how to solder good enough to make it stick. Got a few pics for yall.
Donor truck.
Mine.
New motor.
Turbo clearance.
Broke off the little elbow for injector closest to the filter while messin with the wiring.
My temporary fix was to grab one off the 6.9 and drill the holes out to 3/16ths ill get a new one along with a new CDR valve and air/fuel filters.
