hi, new to the forum, but been lurking a while now.
I have a brake problem, and i need some guidance.
Engine off, super hard brake pedal.
Engine running, pedal will go to floor, sometimes. Then the brake light comes on. But this
is only sometimes, mostly at idle. On the highway, or around town, steady rpm, no issues.
Really good brakes actually. But i want to fix this before any thing surprising happens.
no loss of fluid, anywhere, yet, that i can see. There was a drop where to master cylinder bolts
to the booster, but repeated engine on/engine off pedal pumping/holding did not create any
more errant brake fluid. No wheel cylinder leaks, no abs light. I replaced the front soft lines
when i got the truck. The master cylinder and booster were replaced a week before i got
the truck. From what i've read this sound like a booster issue, but i just wanted to be sure
i was heading in the right direction.
Thanks in advance
Thanks in advance
