New guy checkin in!
1320Cummins
Pro Parts Thrasher
San Leon, TX
New guy here lookin for others with a love for the IDI. I have a 88 S-1600 with the 7.3 and a HY-35 I installed and a newly acquired 94 f-250 factory turbo IDI.
Hope to hang around a while and learn a few things:peelout
What is an HY-35?
Feel free to use our testing forum for additional signiture experiements.
1320Cummins
Pro Parts Thrasher
San Leon, TX
Here are a few pics I will post more later when I have time.
funnyman06
Coventry, RI
That thing looks awesome, looks like someone took some time on that rebuild, it runs pretty good im guessing? I am also interested in how much boost you are running, if you dont already you should look at putting in a ford pump so you have access to the higher RPMS these engines can provide.
1320Cummins
Pro Parts Thrasher
San Leon, TX
Thanks guys. I did the whole build myself. I have the turbo wastegated at 15psi. I am kinda in a rush now but I will post more pics later and add more specs and info.
1320Cummins
Pro Parts Thrasher
San Leon, TX
Here are a few more of paint and install.
The engine contains all stock size Sealed Power, bearing, pistons (with teflon like coating on skirts), rings, FelPro Blue Stripe gaskets and seals, Melling oil pump, Airtex LP, rebuilt heads by H&H Machine, brand new appearing crank, a very nice looking block with exception of a scored #5 which was sleved by Rollands Machine, topped off with Borg Warner K code injectors and a bunch of mis-match lines.
What would I do differently next time? I would go to a junk yard and pick up a factory turbo IDI
Within the first 2,000 miles I broke #1 wrist pin. I suspect it to be defective as I now have about 7,000 trouble free miles on 4 more new pistons and wrist pins in that bank.;Sweet
I am not sure what pump I am using??? it has good power to 3200 then de-fuels on to 3600 under a load. I was thinking about installing a reman 94 IDIT pump but have yet to see the need.
The truck runs good for weighing 13,400# empty I raced it against another guys Top Kick 3116 cat with fuel turned up about 85% we stayed side by side to about 3rd then the IDI quickly pulled away. We tried again and again with same results every time!:D She will pull a pretty good grade at 50mph weighing 34,000# (s-1600 is only supposed to gross 26K).
In the future I want to build another one like it except a crew cab with a flat bed and a compound turbo P-pump DT-466.
