Andylad13
DieselBoy
Took off the bed today via backhoe, too look at both tanks because they are both leaking. Im doing one at a time, so only the front is out. I heard that bronco tanks will work, but what i cant find out through searching is this...is there a bronco tank that you can buy that will work with out modding the sender assembly? I can work with splicing the wires so that the connector will work, but i dont want to be putting extra components on the sender. Also i know that the bronco tanks are for the rear replacement, and i would run one bronco in the rear and perhaps fix my front.
