ConstantVigilance
I have a 6.9 idi with a zf-5 and SMF.
A few weeks back I noticed my clutch becoming softer, or "squishier". After some more driving, I suddenly couldn't go faster than 35 or so.
I found some information about inspecting your clutch pedal linkage and fire wall. Fire wall seemed fine, but my master cylinder push rod opening was warn like an oval and the dowel pin was very warn with about an 8th inch taken out. I found the "Heim Joint Clutch Pedal Modification, By Ron Butts", on this site, and followed the steps.
The clutch still "slipped".
I recently replaced the clutch master cylinder, so I went ahead and replaced the slave cylinder. Made no difference.
I then replaced the master cylinder anyway (they did a warranty swap), and when that didn't work, I replaced the hydraulic line.
Each time I did all these things, I would bench bleed the setup and reinstall. The clutch always felt the same. (albeit SOME difference after the heim joint mod, but still limited to 35mph)
I dropped the transmission. The clutch was warn but dry. The pressure plate "spring" was very warn... and the release bearing was also warn, both were it pushes against the pressure plate and probably an 8th inch marks warn into it from the release fork. The fork was warn also.
I finally ordered a new fork and clutch kit from LUC.
I ordered the "" LUK 07131 (Daily Driver) RepSet®"" from RockAuto.
A previous owner installed the SMF, so I got it machined and reinstalled it.
Today, I finally got the truck back together. First thing I noticed was the clutch pedal felt much stiffer than before. (keep in mind, I have not re-bleed the system sense installing a new hydralic line). This gave me hope, for sure.
Pulling out of the drive I let the clutch out and could hear the engagement of the clutch. Like the sound your breaks make when you free spin the tire when its up on the jack. Its a rubbing sound. I can hear this clearly because I have not reinstalled the tranny shifter boot. I can't tell for sure, but it almost seems like they continue to rub even after the clutch is all the way off. The motor bogs down and gets louder so I can't hear so well.
It DOES begin to engage almost immediately and continues to engage until I'm most the the way up.
But I am still only able to go about 35mph. In fact, the rate of slippage feels no different than before.
I would greatly appreciate any ideas. My first thought, of course, is that the flywheel had been re-surfaced too many times.
Thanks, in advance.
Thanks, in advance.
