kas83
I got a set of 255 Coopers 2 weeks ago, and have been running them and loving them everyday since. Today, I got some landscaping rock, a decent load, and was unpleasantly surprised to see the tires touching sidewalls when it was loaded down. They are D rated, 3000 lbs each at 65 psi, I have 65 in them. I kinda figured they'd need spacers, but was hoping to get by.
Anyways, where can I find a good set of hub-centric spacers for this truck? Ones that will allow me to run my current wheels with the locating pins on them. Or will I need to grind/machine those pins off? And will a spacer hold up to hauling a 7-8000 lb camper a few times a year? I'm by no means maxing any of the tires or the truck out with what I do, but I will be working it.
One last thing, I'm planning to get a set of aluminum wheels off an 08-10 Chevy or GMC dually, the 17 inch ones that look like they are dished real deep, after I get the bodywork done. At that point, I plan on running a 265/70R17 E rated tire. Does anyone know the center bore for those? I would like to be able to use whatever spacers I get now with those also. Thanks very much in advance.
