i had a factory turbo engine laying around so i pulled the ip off ( might only have 1500km on it) put that in my truck. it starts and runs nicer then ever but it still has a slight id say miss at a idle like before the old pump died. i do have one injector that is not totally tight in its seat cause there was a slight amount of diesel around the threads and its bubbling, going to fix that tomorrow and on the same injector the one return cap is starting to leak. would that cause a stumble in idle? it starts fine after sitting so it isnt sucking air when not running. just something is up when idleing, also when it locks up in OD it stumbles then as well due to low rpm and load. so i think im gunna drop in a known good set of injectors and return lines and try that out. im starting to get annoyed with thing after thing going wrong and making me wanna do my cummins swap sooner but thats not realistic yet as im still rebuilding it and saving for parts. so ya whatcha think? if what ive typed is confusing ask and ill clairify i kinda seem to just type and type till everything is out and nothing makes sense the second time i read it and ya thanks guys
