Headhunter_5.9
there it is Johnny!
Alright!
I’ve been wondering and pondering and trying to find the answer but couldn’t, so I’ve sucked it up and I’ll ask, which is what I should have done in the first place!
Got two issues possible Problems!
2000 Cummins w/ a5 speed, 171,000 Miles, 2x4. 65 HP bully dog, straight pipe. <-- NOT THE PROBLEM!
All pertant info outta the way, I’ll proceed!
First. I had a clutch put in it @ 150,000 things were fine, turned the fly-wheel, the usuals, at any rate recently it started w/ a weird grind/growl when in first or reverse, notice it more when the motor is under a minor load, the other deal it’s doing is bucking/jerking when backing up w/ a trailer when everything is warm! It sounds and feels like it’s in the drive train? Checked the U-joints and they seem to be all good!
OK problem 2!
I’ve been reading all the lift-pump “stuff” and I’m at a total loss here! I’ve noticed here lately that 4 gear is a DOG real weak and the boost seems to be mildly slow to respond when pulling the trailer! (4 horse, 22 ft.r) so before I go checking this and screwing up that, I guess what I’m looking for are some numbers, what’s the tolerable levels of Fuel Pressure at an Idle, cruise, wot? My learning curve here isn’t real steep and I’m not afraid to DIVE in as long as I’ve got some Knowledge of what the hell I’m doing! along w/ the best way to get said pressure checked!
And on the topic of the LP as far as I know it has NEVER been replaced! I got the truck w/ 81,000 on it and the PO had it from birth! So what’s going on under there I can Imagine but wanted to check w/ the experts prior to doing anything! I’ve read about moving the LP and about which “PUMP” to replace it w/! but I’ll ask again> what would be the best/easiest/most economical way to do this?
Thanks ya’ll
JOSH
OK problem 2!
Thanks ya’ll
JOSH
