Need part #
Exekiel69
Anyone have the motorcraft part # for the air fuel and oil filters? I have My wix book so I can get the reference part # and order all from filter1 since I order most My other filters from them but I don't have motorcraft #'s, any ideas to get the right ones from wix?
Thank You.
tgatch
Racor #: 32442C93
International #: 1847170C92
WIX#: 33899 (no membrane around the larger filter for water separation)
Motorcraft #: FD4604
FORD OE #: 3C34 9N074 BA or 3C3Z 9N184 CA
If any filter you order does not have the white membrane around the larger filter, do not use it. It is what is needed to separate the water out
Double-S-Diesel
parts seller
derry pa
according to the ford rep Use only motorcraft fuel and oil filters, wix do not fit right, and also do not have a water proff membrane on them.
tgatch
Well I figure the actual International one is safe. Being that they actually build the engine.
Mike
Stroker
Cora
According to Harley, the only approved oil in their engines is Harley Davidson oil.
harley doesnt make oil
olsen726
