Need help with fastener tork ?
Mudbillyrednec
dayton , ohio
I am in the middle of putting in a 1990 12V into my ford crewcab
I have motor out and am switching the trans adapter plate over to a 47rh type..
I have 3 questions about how tight some of the bolts, I'm messing with are supposed to be ??
#1 , the bolts that hold the adapter plate to back of block ?
#2 , the bolts that bolt the motor mounts to side of block ?
# 3 and I'm sure some will laugh....valve cover bolts
Thanks in advance, I;m just not good with computer reaserch :dunno
crashnzuk
West Sacramento CA
The valve covers are 18 lb/ft. I don't know what the others are, I checked an engine specific manual, and it doesn't include the parts required to mount it into a vehicle. I would just go with a general torque value for the size of the bolt you are using.
Travis..
Cowboy_Customs
Rhinestone Cowboy
Binghamton NY
I will have to look at my FSM and get back to you. It is at my shop unfotunatly. I think 80 ft lbs? That sounds correct, but dont quote me.
