Need Help, Fuel Leak
RGMS4X4
Magnolia, TX
Started my truck to warm up and went inside. Came out and saw fuel dripping
on the ground. On the top of the fuel filter bracket there is a small black
cap or plug with one wire comming out of it. Fuel is leaking from under this plug. Does this plug come off? How can I fix this leak. It's loosing alot of fuel and dripping on the exhaust manafold.
Thanks
Randy
sle2115
NRA LIFE MEMBER
Southeast Ohio
This is probably fuel leaking around the fuel heater which is housed inside the filter head. I believe you can get an oring for this and fix it, prolly a Ford or IH item.
RGMS4X4
Magnolia, TX
Thanks. Guess I will see what Furd wants for it.
When I get this fixed, she's going up FOR SALE!
Randy
Dsl_Dog_Treat
Decatur,MI
The part is an IH only part. tell em it's the o-ring for the fuel heater element on a van or a U-haul truck either will work. Ford only carries the entire heater assembly for about 150 clams.;Sweet
To take it out you have to remove the fuel filter and then there is a brass fitting(nipple) that the filter mounts to. I cant remmber right off hand what size wrench it takes, but the brass nipple will turn off and allow the eater plate assembly to drop down to access the o-ring.
pwrdbyidi
The nipple is 1 1/4". Any idea what the IH part # is for the heater?
gabbyr100rs
Acworth, GA
Check the integral fuel heater thread from today. Your part numbers from IH are in that thread. O ring and the fuel heater assembly.
Brass plug that holds the heater in place that the filter screws onto does take a big socket. It was the largest one I had in my deep well metric set--can't recall the size.
Good luck.
spencnaz
Does this info pertain also the 6.9 fuel heater as well? I'm having problems with air in the fuel system as well.
