94IDIT
My '90 7.3 has been starting hard latley. So the other day I looked underneath the truck while it was running and saw fuel leaking on the ground, this wasn't a slow drip either, it was coming down pretty quick. No stream or anything but it was pretty bad so I crawled under it and the drips are coming off of the bottom of the lift pump, between where the lines go in. I looked up higher on the engine but the leak didn't seem to be coming from any where above there. The lines going into the lift pump don't seem to be the culprits either. My questions are, where do I start looking when tracking down a leak like this? What are the most common causes for fuel leaks on these rigs in general? Thanks in advance for your help!
