mahatma171
Return line leaks won't make it die after it's been running for awhile, but they can make it hard to start if your lift pump checkvalve is not working.
If it died going up hill maybe your tank(s) are low
^^^^ x2 I can't imagine a leaky return making your truck die out after its warmed up. Right when you first start it up from cold, yes. But even then with some full-throttle cranking and pedal pumping in between attempts you should get it to re-start.
