Need Advice
Bear
I recently bought a 98 3/4 Ram 2500 with the 5.9 Turbo Diesel in it. Does anybody have any recommendations for plug and play horse power?
argve
Resident Fruitcake
Gwynneville, Indiana
So you have the 24 valve flavor then I would recommend the Edge Juice with Attitude - a buddy has one it's simply amazing how much it brought his truck to life - his is stock otherwise.
dieselbeef
a 98 1/2 ton ram w a 24 valve?
1/2 tons dont have diesels
98 is a 12 valve most likely
Whit
lost in Why-homing
98.5 is the first of the 24 valvers
If ya already have gauges then get an Edge EZ...........used ones everywhere for 250 each............I have never heard of one going bad
rebel_horseman
Rt. Wing Extremist
West Florida Republic
Yep gotta agree. The Edge is a good product all around. The EZ will give you about 60hp with managable EGTs and not much overload on the clutch. You'll probably pick up a couple MPG as well. DiabloSport makes a similar item called the Power Puck. I had one on my '00 and really liked it. Just enough extra power and smoke without much craziness. Got about 20mpg with it in a 4x4 3500. EGTs never got over 1100 and made about 21psi boost.
If you're looking for more power then go with the Juice/Attitude combo or the Edge Comp box. Both are good.
Cv axle
