Need advice what compression and leak down gauge?
kristhewelder
Aldie VA
Hi I have an 88 e350 and a 91 f350drw the f350 has water and is hydrolocedthe van runs good if 350 has blockrot In will put the van motor in it
would like know how to get the proper test gauges and any other thoughts you may have. Thanks Kris erickson
rhkcommander
Oregon
Make sure you get glow plug fitting, the injector ones aren't accurate
Harbor freight ague are junk, the fitting can work with some cutting but the gauge itself is junk. Bought a different one online that worked a few tries and then stopped... I think the sealing oring popped and decompressing hurt it :dunno
Looks like cheap ain't the best route sorry
