NEED A WIRE COLOR ASAP!
none.
the only thing the steering column has involvement is the slider switch. the harness is the main harness on the truck
On top of the lower part of the column is the ignition switch. There should be a red/lightgreen leaving the switch that feeds the fuel shut-off.
It also feeds the fuel line heater, the fast idle/advance temp switch, and changes colors at a splice and feeds the voltage regulator.
