well i can change as needed theres so much out here for these turbos is why i choose it also i dont want it spinning too soon
this should come in to the power range 2200 rpm or so
so at peak torgue for me 1500 or so (motors not stock) it will just be starting to build boost
and at 2200 (most common rpms im at while towing) it will be making good boost
also the larger housing causing lag will me to watch the boost gauge this isnt going to be a fast truck just strong as hell
also the motor is stroked to 7.6l or 7.7 idr which but the larger motor will flow more also it will get a 4k rpm spring so a bigger housing seems ok to start with
