my turbo build thread and other junkm pic heavy
88beast
pa
ok heres the air filter im gonna order gimme opinions on it ive only heard good about them
88beast
pa
need parts help
i need to find a few thing one is the flange for the manifold pattern someone on here had a build with all pics on facebook and he used these things but i dont rember much more than that
also i was thinking maybe have a machine shop make up a flange for the exhaust
also i found the weld els but i need a cheap t3 plate for the turbo to mount to all cheap ones i found i wasnt too sure about the site and anything you know you can trust it was like 40 bucks i could have one made cheaper
also when im done ill be selling some products like the battery tray im going to make and the manifold setup so if anyone wants a custom manifold let me know
88beast
pa
ebayed a t3 flange 15 bucks shipped sweet itll be here when it gets in idk when that wil be im new to ebay
88beast
pa
ok i swapped the master cylinder out today and brakes are much better ill get soem pics up tomorrow
88beast
pa
pics update im getting manifold parts now
now after the distraction of darrintosh s new dully
glad to see him with an idi after the cummins swap
but this will be the way to connect manifolds together through the crossover pipe one will goon the pipe other will go on the manifold
the pipe one will be clamped for now because i plan to have a piece made to just replace the y for now then get a new pipe made up
also with the t3 inlet flange on the way all i need is a huge mcmastercarr order soon
88beast
pa
new 37s on didnt take much now to get on that turbo and toss on the lift quick
88beast
pa
got the t3 flange in today in the mail not so great quality but itll work fine
heres it on the turbo
i got some 1/4 plate i plan to cut up and use to merge the pipe into the flange im going to make a 3d plan tonight
88beast
pa
i think going to a single inlet will help i may make some sort of divider to help flow or just port the turbo housing but would this matter much?
88beast
pa
mostly finish theres some pitting from the casting on the outside and the gasket surfaces arnt polished plus the outter and inner edges (where the air flows and the outside) arnt perfectly even nor on spec for a t3 the inner is slightly larger
and his picture on ebay was perfect
basicly i wouldnt recomend this one if you didnt want to do some porting
88beast
pa
m2rtin
