My IDI Diesel
dieselM715
Feep builder
Cameron Wisconsin
I picked up my parts truck last weekend.I bought a 1988 F250 4x4 5spd.:thumbsup:
My plan is to use the engine and find a two wheel drive ZF5. Then install it into my M715 Jeep with a few mods for alittle more power and reliablity.
I do have a question for the ZF experts.I have a two wheel drive Zf5 for a small block Ford.My quwstion is can I use the tail housing and output shaft to canvert a 4x4 trans to two wheel drive??
Thanks
crazy4wdracer
PA
I'm pretty sure that will work. I think the only differences between the small block trans and the diesel trans is gear ratios and bellhousing.
Worstenemy453
King George, Va
If you decide to get rid of the 4x4, can i get the pedal assembly and stuff required to use the manual in place of a C6. I want to do the conversion.
dieselM715
Feep builder
Cameron Wisconsin
I will be getting rid of whats left the truck after I pull the motor ,but as for the parts needed to change to a manual, the pedal assembly is about all that I wount be useing.
