Some of you might remember my glow plug thread awhile back. Long story short I had one of the two yellow 10ga wires melt and loose connection inside the wiring harness plug on my passenger side fender and I found it very hard to trouble shoot with the tools and knowledge I had at the time. It basically melted between the battery and the controller loosing connection with one of the two leads to the controller. Well knowing nothing about this type of circuit it took me a long time to figure out the problem and while checking for voltage with my meter everything seemed to work great (one good wire will still show voltage in the system...) other than I had 12 volts of power from the solenoid but it would not carry over to the GP terminals under load
Anyhow I thought I fixed it as I now have 4ga. cable ran from my battery to the relocated controller/relay (mounted on the passenger side fender) then 4ga. to the leads on the GP's. I thought that by using on one HUGE 4ga. cable to replace all of the two smaller 10ga cables throughout the whole system I would not have any lack of juice and therefor it would work better than it ever has. Well as it turns out (and I found out the hard way) the controller works based off of resistance between the GP's and controller and also water temp so the single big cable really screwed things up for me resistance wise.
At this point... As my 91 is frozen in the back yard I'm wondering
1. Why in the hell did Ford decide to use 2 10ga wires from the battery all the way to the GP's in the first place instead of one BIG ol' cable? Is there honestly a reason for it that I might be overlooking?
2. Why did they use 2 10ga. wires that are typically rated for 30ish amps max each when the system can draw up the 200 amps?!
3. Why did they design the controller to switch off when x amount of resistance is met making my "upgraded" 4ga. cables not work? 4ga. cable = less resistance = shorter glow plug cycle = 5 second cycle not long enough in temps under 40*.
I am now going to keep the 4ga. wire from the battery to the solenoid. However I am going to scrap the 4ga. cable from the solenoid to the GP's and replace it with two 10ga. cable to mimic the stock setup. hopefully the extra length from the GP's to the fender where the controller is mounted (an extra 12" or so) won't mess up the timer too much. I'll keep you guy's posted on how well that turns out....
It just bugs the hell out of me because every 6.2/6.5 and 6.9/7.3 has been a nightmare to start in the winter if everything isn't 100% PERFECT in the GP system... And really I wonder if it can ever be perfect due to the underrated equipment used in the first place. Everyone asks me if I'd swap my IDI one day for a Cummins, and honestly the only reason I would it do such a thing is to pound the last nail in the glow plug coffin because every time winter rolls around (Northern Utah + winter = cold as (%#@^!) I think it would be well worth it!
Right now I'm thinking that the push button is the only way to go. The 10ga. wires are obviously under rated, and i really feel that's the reason we struggle with the entire systems reliability especially the GP's, and there is no way to supply ample power to them with the controller because it can ONLY function based off of the resistance of the two underrated wires... Yep pretty sure the push button it the solution
Sorry for the rant.
Sorry for the rant.
