my dyno numbers are in.
Status
Not open for further replies.
NMB2
Dunce
Ft. Lewis, WA
My truck was dyno'd on a Mustang dyno. Mustang dyno's are much more accurate to real world power than DynoJet's, which are very well known to put out inflated numbers. For this reason Mustang dyno's have a "Dynojet corrected #" for reference between the two.
http://g35driver.com/forums/engine-...ction/26743-mustang-vs-dynojet-good-read.html
Black line is torque
Green line is horsepower
red line is boost
Corrected output numbers:
321rwhp @ 3200
558rwtq @ 2200
My dyno sheet pull video:
http://www.youtube.com/watch?v=-4xnCWBl_PU
Mustang Dyno sheet is here :
82F100SWB
Sioux Lookout, Ontario,CA
Very impressive numbers, I've been expecting this.
The Mustang VS dynojet is an old debate, and the numbers can't be directly compared, as he said, there is a correction factor for Mustang numbers to compare to Dynojet's higher ones. The Cummins guys throw that one about on a regular basis.
88 Ford
San Diego, CA
Wow, those are some good numbers!!! I wonder what your numbers will be next run? Also I think those are the highest numbers I have seen. Does anyone know what type of dyno Heath's pull was on?
88 Ford
San Diego, CA
Oh and ;Sweet So many thought 300 hp and 600 lb-ft were nearly unachievable. Those are moderate mods on your engine and now your next run will prove differently!
jonathan
sullivan In
dyno sheet also cleary shows my HP is still rising....it never drops off, that is my 6psi of boost missing in the equation.
I also must admit I was wrong from another thread, dyno guy was certain my d-train loss is closer to 30% than 15% with the ZF5 and sterling.
thats awsome ;Sweet;Sweet:hail
NMB2
Dunce
Ft. Lewis, WA
and before anyone says it.... my starter isnt slow, I wasnt paying attention and had the truck in gear!! DOH!
88 Ford
San Diego, CA
well 602 on a dynojet, which is not a very realistic number, it is inflated. my 558rwtq is the accurate number.
With my air filter situation fixed, and actually being able to burn off my fuel, like I usually do on the street. I'm expecting my Mustang Dyno numbers to jump up into the 230rwhp range and close to 580-590rwtq range.
Looking forward to adding an intercooler, turning my pump up, and jumping up into the 25psi range in a few months.
Still man you are close to 300/600. Maybe some water/methanol or some propane to help it out a lil bit. :sly
NMB2
Dunce
Ft. Lewis, WA
I'm definitely over 600tq at the crank... closer to 650tq at the crank. I think these next dyno pulls will jump me up to around 275/700 crank mark just by ajusting fuel and fixing my boost (IE, find a filter that my turbo wont implode)
FORDF250HDXLT
Maine & Oklahoma
pretty dang impressive!
thats a lot of nuts getting to the ground.
your success has now traveled to another diesel forum.:D
NMB2
Dunce
Ft. Lewis, WA
I'm really at a loss for what to do with my filter. that IS the filter for 7.3 PSD guys and my turbo collapsed it. Looks like I need to do some research. If I don't find a new filter by the weekend, I will probably just run my pulls next week without a filter on the tube.
racer30
western Oregon
Verry nice... The graph has no rpm info?... what were you turning when you finished your pull.
david85
Campbell River, B.C.
You have our attention.;Really
If I ever switch to a better turbo in my truck, you have me wondering about the air filter. That was just crazy.
And yes, I was wondering about the startup too.....;Poke
Status
olsen726
