My Big Blue Ox build....
Startin to like the auto....***...hmm how now says I to have the E4D0A rebuilt...hmmm
Sell rebuilt c6 n zf kit....hmmm perhaps
What are you doing for fans?
Guy said 7000 CFM.
Guy said 7000 CFM.
You will see...resting some build materials shortly!
So drove like 3 hrs to check out a few things...most importantly rims for ranger.....turns out the idiot doesnt know what or how to use or read a tape measure...the 3 inch centre hole turned out to be 2 3/4 after 3 hr trip...useless to my need.
But got 3 TEAM CVT primarys fkr free on way home at John Deere dealer
Also we bought this 72" gyro mower for 300 bucks...need a paint job due to some mknor flame damqge....nothing but paint and a plastic pto guard damaged.
Selling it may e for 1800
My neigbor needs one and aske Brian to look fkr one. LOL
Truck rolled flawlessly with that on was great.
Also scored a roll of blue auto carpet..pefect to do some work in cab of truck.
All in all an ok day...oh ya zf pto with hyd pump...800 bucks.hmmmm
Not right now....sure like driving auto....hmmm need find e4od
Does anuone knkw if 2wd internals swap to 4wd case easy?
Thanks for looking
Drilled holes and temporarilly mounted seats...gotta build some plates to reinforce floor now...sure are comfortable.
Also kinds sorta scored these..guy basically gave em to me ...but offered sell me some 235 75 15s
These are 11.00 x 16 x 38 Michelin XL that need recut tread but being regroovable..and having a grooving iron am set.
Lots work...now MUST get 60 in and 4" instead of the 2" rear blocks
Thanks for looking
Bought this roll of Blue auto carpet and a can of spray adhesive. Last night I cut the carpet for my rear seat so the bottom and back when flipped down would be carpeted for my dog as she slides all over when driving on that steel backing.
I had thoroughly masked off the one section sprayed glue and did same to carpet backing.
Here is seat unmasked but glue in place drying so I can lay the carpet in
Carpet same..glue on drying
Half carpet in and then I remasked the cab and carpet sprayed glue..voila
Ahhh completed....not exact match blue...but dog dont care.
Dog approved I see
And the 90 buckets in place...saweet comfort indeed. Thanks to Brian in pic for helping with carpet
So now its onto figuring out an idea for a guage pod....stay tuned for that if it works as I hope it does....
Ordered two Front spring rear eye bolts 24 bucks each get em for 15 ea...***...they are likely getting drilled for grease nipples so I dont loose em...maybe....I hate rusty spring eye bolts
Once they show then I can work on tossing in the 60
Thanks for looking...
F350camper
BOOST!
that carpet is going to work out slick, errrr ahhhh not slick... well you know what I mean, good job!
Holy cow those are pricey bolts. Nice job on the carpet and seats. If I could have found a mate to the 91 passenger seat in mine, I'd have kept them. I really like them.
Looks good Al!
Was under the truck checking the ABS unjt to see if plugged in...yuppers...and noticed what appears to be leaking oil cooler...dob....pmo...k nother reason go to pick a part n grab more from turbo truck.
So been driving this beast a while...seems ok...went to Pauls Automotive ...has exhaust tubing bender machine....discussed a redo of my Y pipe and he is game...50 n hr rate
Decided to check rear brakes they seemed a tad soft and weak. Good shoes...out of adjustment....then norm. I re-adjusted and now it appears they work well. Noticed that one park cqble is messed up so need replace that. I beleive I have a couple good ones i stock too.
Plenty of shoe...both sides same
Here Brian is packing the tyres...moving to rear of shop...
Decided to attempt to PRESS OUT my bolts on my Front spring eyes on the 60 springs...here is my Lil press frame and how I set it up. I was able to press the bolt out some...however the frame isnt large enough to press it through so now I am soaking the bolt with liquid wrench. I hope this works then I can LUBE the bolts and have much better ride.
I will work the bolts for a few days...hope they come out soon.
Thanks for looking
Boogers...
Been trying to get rear abs light out....crap..changed sender nope wiring harness from frame to semder nope ...next is stupid abs unit I suppose...hmmm now what to do. Guess gotta get one from my parts truck/s and clean it up make sure A OK and bleeder nipple can move.
May as well prep to install ABS unit at same time when my hydro goes in!!! Gotta bleed brakes then...why do it twice?
Crap...lol
There is also the tried and true method of removing the bulb.
Hey, is that firewall pad in as good of shape as it seems, if so I need it. The dually needs to be quieter for a road rig. Cant hear the wife, wait, maybe I , hmmmm. yeah I need the pad.LOL
MadScientist
