My 1994 F-350 4x4 CC TD
SLC97SR5
UT
Current pic, she needs a wax:
SLC97SR5
UT
Beautiful truck.
Did you ever get that I/C plumbed? ;Poke
Thanks!
I wish. It hasn't been a priority but what is really holding me back is that I want to utilize the stock air box. I think it is too cool of a piece to throw it out and that really limits my options.
Keep poking, I need the motivation. ;Sweet
SLC97SR5
UT
RotBox reminded me that I never really documented the Hypermax Smoke Puff Limiter install or impressions.I'll throw that up shortly.
92F350CC
Ford Man
Las Vegas
Thanks!
I'm pretty sure you can use the stock air box. My uncle's 94 had an intercooler and was running the stock air box.
Sent from my Nexus 4 using Tapatalk
reklund
Henderson, Nevada
No reason you can't use the stock air box. I have the stock air box from my ATS turbo (Identical to the Ford box) and intercooler on my old truck.
SLC97SR5
UT
Scouting for places to shoot...
SLC97SR5
UT
Although I did not intend on using the Toyo tires for dirt duty other than pulling trailers into dirt lots, they did very well even at 65psi.
Earlier this month I passed emissions testing in one shot! I still need to post up about the Smoke Puff Limiter.
NO_SPRK
User & Abuser
Santa Rosa, Ca
Hows it ride with a top heay load? Those tires look squeezed on the rims
Sent from my SCH-I605 using Tapatalk
SLC97SR5
UT
Aside from a load to the dump the most top heavy load I've had is probably the goose neck trailer...I dont consider that top heavy...not like a cabover camper. Either way they fit good and have an excellent load rating.
When I first had them mounted they seemed squishy and a bit squirrley, I'm assuming because of the tall tread blocks and deep sipes. After 1k miles they calmed down and all has been good.
A few pages back I have some comparisons to the old tires and some links to reviews.
NO_SPRK
User & Abuser
Santa Rosa, Ca
Thats good. Ive run 285s without issue but my mind keeps telling me all the tire manufacturers require a 7.5inch minimum width
SLC97SR5
UT
You are correct. That is why Costco wouldn't mount up a set of 285 Michelin's. In fact they would not even mount up the 265's I originally had on there. 235's only.
I think the 285's are a great size for the 4.10 geared trucks as they give some additional run out and require no modifications to fit.
Most of the Super Duty's out here are running 285's on factory rims.
NO_SPRK
User & Abuser
Santa Rosa, Ca
Ummm costco has problems then. 265s will mount just fine and are so close to the original size. A tiny bit shorter but obviously wider
720Diesel
