My 1994 F-350 4x4 CC TD
SLC97SR5
UT
Here is my new to me '94 F-350 4x4 CC TD Auto:
It has:
3 pillar pod with; Transmission temp, Boost and Pyro.
Brians Truck Shop E40D
2 Tru-Cool transmission coolers -- big difference in trans temp
Dual 875CCA Interstates -- MTP65, averaging 4 years per battery
ATS exhaust housing
3" exhaust, straight piped
4.10's
Factory Alcoa's
285/75/16 Toyo OC AT II
IP replaced with a MOOSE pump
Pop matched BB's from Mel
Hypermax Smoke Puff Limiter
'99 Powerstroke intercooler mounted, needs to be plumbed.
Heater core bypass with vacumm switched valve
Larger Powerstroke oil filter--Wix 51734XE synthetic media
Wix 3617 fuel filter replacing 2 piece unit, retains all factory sensors.
New 130 amp Alternator
New Mitsubishi 3k Starter
Aluminum radiator
New Motorcraft water pump
New Master cylinder
New spicer u-joints
ALL fluids flushed and filled -- brake, ps, gear oil, transmission, radiator
Shifter cable adjusted
New tach sensor
New fuel olives
New return lines and caps
New BERU glow plugs
New serpentine belt
New idler and tensioner pulleys
Boost bumped to 14 psi
Timed to 9.5* PBTDC
Aux fuel tank
Window tint
AVS bug shield
In channel vent visors
Bilstein 4600's- yellow cans
Cobra 19 DX IV CB
Currently running PS Diesel-Kleen, Stanadyne Lubricity and 2 cycle oil to freshen everything up.
The Truck has never been used for daily driving, used on the weekends to tow the Toyota's and a monster 5th wheel.
Towing our Toyota's:
SLC97SR5
UT
Thanks for the website RotBox!
The drivers side bed corner got mauled by a blow-out a few months ago, before that the entire Truck was straight and flawless.
The Truck has 104K and has required very little service, the MC is leaking, the RABS valve is giving a soft pedal and the lift pump was replaced a month ago, I still need to get the cruise control recall complied with for now it is just unplugged.
The plans are to clean her up, catch up on some maintenance...SCA and rear diff oil and keep on driving it!
Rot Box
Northern Utah
Lewiston
You bet ;Sweet I doubt there is an IDI question that hasn't been answered on this board--great community. Blackdog is also an RME member over here.
Again nice truck! You should get that IC plumbed in and post up the results ;Really
6 Nebraska IDIs
SWEET Truck man! You obviously put some time into that thing cus those wheels werent available until 95. :)
SLC97SR5
UT
The intercooler will be a big project since we want to retain the factory filter/airbox setup, definetly a summer job...I will post results.
Thanks for the comments guys!
I got the Speed Control recall done today, it took them 20 minutes in the parking lot.
I'm looking to adjust my wastegate to limit boost as it easily hits 17psi just getting on the freeway unloaded, I have seen 18psi when towing.
What is considered a safe boost and pyro level? I've done a ton of reading but there are some conflicting suggestions out there.
agp23109
Vacaville, CA
Nice truck. Looking forward to the intercooler update. I have a very similar truck and I'm getting ready to install an intercooler. Good luck!
SLC97SR5
UT
I am confused by the "97" intercooler? Being an intercooler did not come on these trucks till 99
EDIT:
You are right it is a '99 Intercooler...as you can tell I'm new to IDI's and diesels in general.
FordGuy100
Silverton, OR
With the stock turbo, anything above 12-13psi is super heating the air. Basically the turbo is spinning so fast its making the intake air temp hot, like 300*F+, and you wont see any gains going higher.
Safe boost is what you think it is. If its holding together at 17psi, I guess you are ok. With a 7.3 with head bolts, I would limit it to 15psi max. Pryo, where is the thermocoupler mounted? If its in the exhaust manifold or right after, 1200*F+ is out of the safe limit. Try to keep it at around 1100*F for a max safe sustained level.
Nice truck man ;Sweet
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
-Drool-Drool that thing is beautiful;Sweet Some day mine will be that nice:rolleyes::sly Do you have any motor or interior pic's?
Highridge
MA
That is such a nice looking truck ;Sweet I would love a crew cab but it would be terrible for me to plow with.
lewisstevey7
