93fordturbo
Right, but with low enough compression to turn out serious hp, it will be difficult to start, thats waht happened with that dps truck of Ken's or whatever his name was. i think if i recall correctly
Any ECM controlled engine will out perform a non ECM controlled one. If you have taken any classes for ECM controlled cars or understand how the ECM controls every parameter of how the engine runs then you'd understand how they do it.
Carbureted engines can be tuned for one specific climate condition, and run perfectly in that climate. However, if any one of the several parameters of that climate condition change, that engine will no longer perform at peak efficiency without retuning.
However with an ECM controlled engine, the majority of the engines efficiency related parameters are controlled via the ECM. The ECM precisely calculates the climate conditions and engine efficiency sensors, then compiles the data and makes adjustments to the engines tune to accommodate for any changes in the climate conditions. The ECM does this all in less than a second (actually probably several times every second) and does this every second the engine is running.
So putting this into perspective towards the IDI Vs PSD topic, an IDI is much like an older carbureted engine, they can be tuned for optimum performance at whatever the climate conditions were during the tuning procedure. Where, as explained above, the PSD is an ECM controlled engine and is no different than any other modern ECM controlled engine, it is continuosly tuning itself based on current climate conditions.
So basically, this is how that modern turbocharged 4 banger just whipped the pants off of your 450hp 429 Cobra Jet. Leaving you sitting there wondering how an engine less than half of your displacement just gave you a spanking, and a mile down the road is cruising along getting 35mpg. lol
anyone got a link to the vids of mels misters? or where i can get the typ4 cam?
EDIT: Oh wow, I didn't realize NMB2 had said he was running 20 psi under 1100* without an intercooler I though he'd said 16psi. WOW Now I'm going to have to pull out the smiley.
Prove it, and from now on when you make a statement like that post the specs of your engine. Quit making dangerous blanket statements without any sort of evidence, where's the videos or write ups on all of these IDI's pushing over 16psi boost never climbing above 1100*EGT without an intercooler, or also in this case specs on your setup since you have supposedly done it.
Ive always felt that that little hole into the prechamber is what is holding power back.
lot of people against the idea.. not sure I understand why though. You're making boost, same thing a turbo is meant to do. You're taking in cool air and while its not intercooled you arn't planning on supplying more boost than a factory turbo without an intercooler supplies. Sure you're gonna take some power to make it, but I think having a blower would be neater than hell. And if you lower the compression theres no reason you cant run more boost. It will be warm air so I guess you wouldn't want to overdo it.
can someone explain to me why this idea is getting shot down across the board? no one here has tried it but everyone "knows for a fact" its a terrible idea and wont work. it's different and may not deliver the wanted results, but whos to say it wont? and its not like he's just slapping a blower on a stock 6.9 and calling it good, he's asking for ideas. rough crowd in here.
