MONSTER TRANSMISSION
FORDF250HDXLT
Maine & Oklahoma
thats good.perhaps you just didn't hold WOT during the scan? though i personally would set it at 1.2v idle/closer to 4V WOT.
how did the solenoid pack connector look? did you happen to see anything there that might be causing code 99? this is the main issue.might be just the plug needs a cleaning again.
zbbcmonster
Hazelton WV
I will have to check the silonoid connecter I will adjust the tps again thought I had it closers to 1.2 and 4 at wot
zbbcmonster
Hazelton WV
I check the tps today and it was off a little in adjusted it so tht it was 1.2 and 4.3 wot I reset the computer by unhook ingredients the batterys for a couple min and then drove it probably close to 25miles seemed to do ok but still don't feel right but od light didn't come on this time but it has done this before so I will test drive again tomorrow I didn't get to check the silonoid connecter maybe tomorrow thanks for the help and any help further down the road
placidoert
