Here is another fun with the metric/standard issue.....
Dad had a 97 Ford Contour. We live in the rust/salt belt, and the rear brake hard line, between the rear wheels rusted through. This line runs along the body, "inside" the channels that make up the rear suspension. To replace this line, all that has to come loose to remove the line. When he picked the car up, the shop that did the work told him that ALL the fasteners, from the center line out on once side were metric, and ALL the fasteners from the center line out on the other side were all standard..... so the assembly line that day, for the rear suspension station, had metric bolts in the bin on one side of the line, and standard in the bin on the other side of the line.......
That was an interesting car to work on.... never know which set you would need.....
