Messed up changing oil pressure switch
Mishka
Fort Knox, KY
Ok, I finally got around to changing oil pressure sending unit and didn't realize it was on a adapter so sadly some of the grime on the engine got into the hole. Should I do a complete oil change with some hotshots stiction eliminator or do you think oil filter w(fl-1955)get it? (Just changed oil 500 miles ago)
Randy Bush
Great Falls, Mt
You could crank, not start a few revs,messy but dirt would pump out with the pressure build up. actually would be best to not push that dirt into the new sender.
Va_Mike
Southeastern Virginia
Totally agree. pull the sensor and crank and blow the dirt out. better to clean up a mess than run the risk of the grit hurting the oil pump.
Alleycat
