Ok so this is what i started with after getting it towed home. Fuel pouring out of the rear tank. A totally full tank was drained completely empty all over the highway.
Called up an old friend and got a rental
LOVE that car. Not as quick as my Mach 1 I sold last year, but very roomy, smooth, and comfortable. I might actually go buy one for a daily driver.
Then it was time to get the parts, I have them listed in this thread somewhere. The beer and sour patch kids are optional. And using a $2,000 office desk is not prefferred, but if you happened to get it from free from your General manager and have no room in your current house for it, it will work perfect as a work table paired with an igloo cooler for a chair.
Then the old valve. I can't say anything bad about it, it lasted 260,000 miles. But wasn't worth $327 at the dealer.
And don't forget, there's still fuel in the lines, so close your mouth when you cut them. I expected a LOT less since the truck stalled out on me, but I was wrong.
I was going to mount them next to the seat, but when I pulled back the carpet I found a rust hole starting and opted not to **** with that area. I'll cut it out and patch it but don't want any fresh holes in there. So I took the transmission hump out.
Not the straightest, most even job, but I did things kind of backwords and I was drinking so i'm just happy I got them mounted
There's plenty of room to work under there, and route the houses away from anything dangerous or moving.
There's a spot next to the wiper switch marked off already from the factory. I drilled that out
