low clutch pedal height
imfixinmopars
hey i thought i would share about the problem i had,84 6.9 4spd,it had real low clutch pedal and i bleed the system,figured on putting a new clutch in ect.....when i was under the dash,i noticed the the pedal moved before the pushrod,and the nut was loose on the pedal side,oops..i tightened the nut,and checked the other side and machined a bushing for the pushrod pivot,and we have a great pedal now,w/o spending anything,hope this helps, :thumbsup:
